wd-45 hand clutch problem
Lyle-Hinckley
10-16-2004 20:07:11
HAND CLUTCH STILL WORKS -TRANSMISSION ENGAGES--BUT THE HANDLE DONT LOCK IN WHEN PULLED ALL THE WAY BACK. CLUTCH HANDLE FLOPS BACK AND FORTH WHEN IN OPERATION..WHAT COULD BE WRONG?? I CAN HEAR A "CLICK" WHEN I ENGAGE AND DISENGAGE LEVER NEAR FORWARD POSITION. IS THIS "CLICK" NORMAL? DONT THINK SHIM ADJUSTMENT WILL FIX THIS PROBLEM BECAUSE THE TRANNY IS NOT SLIPPING. ANY IDEAS??
wdTom
10-17-2004 16:59:08
 Re: wd-45 hand clutch problem in reply to Lyle-Hinckley, 10-16-2004 20:07:11
If the play isn't in the external linkage, which you can see if you look, then take off the battery box and cover and look into the clutch housing and see if you can see. This isn't hard and you may see something like the setscrew loose as was suggested.
Burgie
10-17-2004 05:52:29
It could be that the setscrew that holds the shifter fork on the shaft is loose.
