I-600 Backhoe
B Stanek
10-15-2004 20:19:32
I have a I 600 Backhoe about 1969 with 4 cyl. diesel need clutch does D-17 or other ag tractor fit. if not where to get same. thank-you
jpuleo
10-15-2004 21:42:17
 Re: I-600 Backhoe in reply to B Stanek, 10-15-2004 20:19:32
I have the same tractor. It looks to me that it is built on a d-15. I have the shop manuals and part #'s If you tell me the exact parts you need I will give you the #. I think some of the gears in trans may be different ratios as some have different #'s than the d-15. He has some d-15 clutch parts. How do you like the machine? The large rotor drum on hoe has been a week point on mine.
http://www.----- --/acatalog/Walt_s_Tractor_Parts_Rebuilt_Clutch_Disc_123.html
Stevein CT
10-17-2004 16:24:01
 Re: I-600 Backhoe in reply to jpuleo, 10-15-2004 21:42:17
JPuleo, I have an I-60 that has broken the welds around the rotary cylinder that moves the hoe left/right a couple of times. Same thing for your I-600?? Just curious. Steve
Jpuleo
10-17-2004 17:59:42
 Re: I-600 Backhoe in reply to Stevein CT, 10-17-2004 16:24:01
Yup! Mine was already broken when I got it. It looks like the shaft that comes out of the rotator snapped. Also, the splined female section that recieves the shaft had also broken at some point. I have welded it all together as one big mass and so far so good. If it breaks again, Im just going to scrap the rotator and drop a 3" round stock shaft in its place and use a hydraulic ram. Is yours broken right now? Any luck with repairs? If you need any help with it, id be happy to try and help.
Joe
SteveinCT
10-18-2004 03:35:27
 Re: I-600 Backhoe in reply to Jpuleo, 10-17-2004 17:59:42
Joe, Nope, seems like the third time's the charm. When I got the backhoe, the previous owner said the rotary cylinder needed to be rebuilt, so I rebuilt it. Still didn't work. I finally noticed the shaft was turning but the hoe wasn't. The last time it broke, I torched off all the old welds and started fresh. So far, so good. But I just blew a hose yesterday, so it's off to NAPA. I like my I-60 a lot, I can't kill it! Steve
