WD stuck in 2nd gear...
Stan(PA)
10-15-2004 10:31:04
Buddy of mine just bought a 1952 Allis WD. Every time he goes into 2nd gear, it gets stuck there. Anyway, from looking through Archives, it seems it is probably due to worn shift lever. If anybody has the "new" dimensions of shift lever, please email me the drawing, so he can build it up with braze. If anybody knows other likely causes for this problem. I"d sure appreciate hearing them.
Thanks..... .Stan
JMS/MN
10-15-2004 13:10:29
 Re: WD stuck in 2nd gear... in reply to Stan(PA), 10-15-2004 10:31:04
Even tho it always gets stuck in second gear, might also be a problem with the bottom end of the shift lever. I would first take that out, and with a flashlight, look down through the tower to compare the dimensions of the top of the shifter forks. If all three are comparable, you might need to just build up the shifter. Did that on my WD45 this summer, usually stuck in second, but that was the most common gear I used. Did not braze mine- just used the wire feed to build it up, and ground down each side. Haven't stuck it since, but might be too early to tell. Top of my shifter forks were worn even, about 7/16 inch, so I built up the lever and ground it down to about 3/8, with chamfered edges, and it shifts smoothly. If you need to pull the tower and forks, it is easier to reinstall if you put the tranny into reverse before lowering the tower. The reverse fork is a bugger to slide around the other parts inside the tranny, to get to the lower side.
Phil Auten (TX)
10-15-2004 11:30:44
This sounds like a worn shifter all right, but the fork for second gear may be worn or bent too. I can't help with the dimensions, but I'm sure if you build it up so it fits snugly in the forks it'll be much better than it is now. Of course, figuring out if the second gear fork is bent will require tear down and a lot more time. I would build up the shifter and try it first. Another possibility is the pivot pin for the shifter. Check this for wear as well.
Phil
Stan(PA)
10-16-2004 15:04:06
 Re: WD stuck in 2nd gear... in reply to Phil Auten (TX), 10-15-2004 11:30:44
Thanks guys! I hope it is just the shifter.....Stan
