WD-45 TRANSMISSION HAND CLUTCH
RAY FROM KERRIC
10-12-2004 19:28:18
I HAVE A 1955 WD-45. WHEN THE HAND LEVER IS PULLED TOWARDS DRIVER, TRANSMISSION IS ENGAGED JUST FINE. HOWEVER, THE HAND LEVER WILL NOT STAY IN THE LOCKED POSITION WHEN IN USE. IT SWAYS FROM FRONT TO BACK. TRANSMISSION STAYS ENGAGED BUT I WANT TO FIX THIS PROBLEM. WORKED JUST FINE UNTIL LAST WEEK. I WOULD APPRECIATE SOME HELP. THANKS.--RAY
COLIN MCAFEE
10-14-2004 13:06:42
 Re: WD-45 TRANSMISSION HAND CLUTCH in reply to RAY FROM KERRICK, 10-12-2004 19:28:18
Try adjusting the handclutch according to any of the service manuals. It"s easy to do, just involves removing some shims from the clutch assy. No major teardown is required. hint: make sure the same number of shims are in each of the three locations.
