AC lift truck????
slimshady
10-12-2004 15:33:55
Has any one ever heard of an Allis-Chalmers lift truck? Looking for firing order. has a 4 cyl lp gas engine. HELP
t weir
11-06-2004 16:27:34
 Re: AC lift truck???? in reply to slimshady, 10-12-2004 15:33:55
get serial no and model no i will get all the specs worked for ac lift truck dealer
John (C-IL)
10-13-2004 17:11:27
Take a look on ebay, there are usually a half dozen or so of them on there. The firing order is 1243. It doesn't matter which end you start on, the firing order is the same both directions. #1 is usually the cylinder nearest the radiator but like I said the order is the same no matter which direction you go.
Kent of SW MO
10-13-2004 07:26:20
What I remember from my days at a Allis ag dealer, all Aliis 4cyl. fire 1432. On a fork lift number one may be the rear cyl.
Kent
Chuck MI
10-12-2004 17:51:27
 I've heard of them... in reply to slimshady, 10-12-2004 15:33:55
Used a couple of them over the years, both LP and electric. Had a LP at the place I used to work at. Had an electric at the place I currently work at untill it died a slow and expensive death.
As far as the firing order, I don't know myself but they are serviced by Van's Industrial Equipment here in michigan. They are also a Kamatsu dealer. You might try calling a local Kamatsu dealer or look up Van's in Cadillac or Grand Rapids.
Hope this was some help.
Chuck
