Shifting problems... HELP!!
Tyler Duncombe
10-11-2004 20:23:36
My father and i have bought a 1952 Allis Chalmers CA. Shortly after buying it we noticed you could pull the shifter out of the trans. We bought the piviot washer and snap ring to hold it in. Only to have run into the problem that you still get it jumping out of gear and have to tear it apart to get the forks in line, and was wondering if the forks are worn out they look to be in good condition. Also was wondering if anyone had the length and diameter of the hand clutch.
dej(JED)
10-12-2004 06:49:13
 Re: Shifting problems... HELP!! in reply to Tyler Duncombe, 10-11-2004 20:23:36
I don't know what the diameter and length of the shifter should be, but that is where your problem is. Try adding a 1/4 of an inch of braze the whole way around the tip.
