Allis B 3 point Hitch?
Chad Caswell
10-11-2004 18:28:59
Has anyone tried one of these on there allis B and can you tell me there limits and how well they work.. Thanks In advance Chad
mike petrillose
10-12-2004 20:19:16
 Re: Allis B 3 point Hitch? in reply to Chad Caswell, 10-11-2004 18:28:59
I have a 3 point hitch on my B it was the best think I ever bought. Its a little light up front. but I havent bent anything. And my brother has but it through things that Im sure it wasnt designed for. The only thing Ive found is that my hyd seem to settle down or leak down when I use a 6' brush hog. So I bought those chains that told it up. they work great
Dana (Iowa)
10-12-2004 09:53:00
FYI - I have a Model C with a home made 3 point and a Woods RM-59 finish mower. I had to add front side weights (90 lbs on each side I believe) and I still have to be very careful as the front end still comes up very easily. Since B's and C's are so close in size, I'm sure a B would have much the same problem. It is do-able, you just have to take it easy with the clutch!
Mike in Ohio
10-12-2004 07:03:15
Looks heavier duty than the one I paid almost $500 at the local ac dealer.The other post was right about needing some weight on the front though. With a 6' finish mower the hydraulics will lift fine but as soon as I try to move forward the front end comes up.good luck Mike
Keith-OR
10-11-2004 20:45:07
third party image
LETS TRY THIS AGAIN
Keith-OR
10-11-2004 20:29:40
Picture did not get posted
Will try again
Keith-OR
10-11-2004 20:27:54
This is one that I built for my AC model C. Almost like the one in your pic.
old
10-11-2004 18:36:28
That looks good I'd say the limits would be the tractor its self a B is pretty small. You might have trouble with the front wheels and not being on the ground unless you add a lot of weight to the front
