wd 12 volt conversion
jd1010
10-11-2004 16:39:45
i just installed a delco one wire alternator and took my mag off and i"m putting a distributor on. with 12 volt wich coil wire goes to the points the - or +. thanks in advance for the help. jason
Steve in N.J.
10-11-2004 18:12:22
 Re: wd 12 volt conversion in reply to jd1010, 10-11-2004 16:39:45
Jason,
Plus (+) side to the key switch, minus side to the distributor on 12V negative ground systems. Make sure you run the correct ohm coil and or ballest resistor for proper current and ohms of resistance for the system. If you don't, you'll have oodles of problems. We have the correct internal resistor coils in stock if you need one..
Steve/B&B Custom Circuits
jd1010
10-12-2004 12:13:18
 Re: wd 12 volt conversion in reply to Steve in N.J., 10-11-2004 18:12:22
thanks steve. I bought a coil that lists the AC 170 180 190 and d-19 on the back and i am putting a resistor inline between that and the points. will this be ok? thanks, Jason
Doug in OR
10-17-2004 18:42:26
 Re: wd 12 volt conversion in reply to jd1010, 10-12-2004 12:13:18
You really don't want to put the resistor between the points and the coil. Reason being that the voltage will not flow from the coil to the condensor unimpeded as it would if the resistor were not there. I'd put the resistor before the coil.
