WC year(????)
Quicksilver
10-10-2004 21:25:02
I have a WC I was told it was a 1942 model. S#117166 it also has factory foot brakes, exaust through the hood and frame number starts an x if that helps. If you need an engine number and frame number to tell me the year let me know. Thanks
acorange
10-11-2004 15:34:14
 Re: WC year(????) in reply to Quicksilver, 10-10-2004 21:25:02
Not all styled WC's had the exhaust exit thru the hood. I have sales books showing side exit exhaust
and my grandpa had a 39' with side exhaust with
no exhaust hole thru the hood. I believe the low
compression kerosene engines had side exhaust and
"gas" engines had top exhaust. A styled WC hood
without a exhaust hole is about as rare as hens
teeth now. I once saw one in a junkyard and now kick myself for not buying it.
Dean
10-11-2004 12:53:04
The foot brake conversion was an aftermarket add-on. I have seen several of these and owned one. Be careful when using the brakes as the levers remain and applying the brakes using the pedals will cause the levers to move backward. Not good for the unsuspecting when hands, arms, or worse are in the way.
Dean
Quicksilver
10-11-2004 15:56:47
 Re: WC year(????) in reply to Dean, 10-11-2004 12:53:04
Hi,just to let ya know it dose not have hand brake levers.
Rick Corder
10-11-2004 04:44:22
Quicksilver, 1942 is the correct year for your Styled WC Allis with that serial number. I believe that the foot brakes were a later add on option from the factory. Someone else might have that answer though. Rick
Rick Corder
10-11-2004 04:47:38
 Re: WC year(????) in reply to Rick Corder, 10-11-2004 04:44:22
Quicksilver, To add to the earlier post,the Styled WC's exhaust did exit through the hood. Rick
