Rotobaler twine
Jeff oliver
10-10-2004 20:25:41
I think we are fixing to acquire a Rotobaler tha appears to be in really good working condition. I doubt we will use it much but I would like to at least roll some straw with it or something. Question is I notices that the rolls of twine are alot smaller than balers use,where can I get bundles sized for the container on the baler?
Thanks!
Kevin Holmes
10-13-2004 05:08:24
 Re: Rotobaler twine in reply to Jeff oliver, 10-10-2004 20:25:41
Jeff, I got twine up here in Ontario, Canada at the Co-Op. I had to go to an area of Ontario where there were Mennonite farmers that still had binders. I use mine in a corn binder. Good luck.
JMS/MN
10-11-2004 06:38:05
You use binder twine. The Roto-Baler uses a lot of twine per bale, so you use a light, affordable twine to wrap the bale.
Jeff Oliver
10-11-2004 21:01:54
 Re: Rotobaler twine in reply to JMS/MN, 10-11-2004 06:38:05
Where can I find binder twine? I am assuming that I would probably have to order it as I have never seen anything callled binder twine around here in NW Tennessee. Someplace like COOP maybe?
JMS/MN
10-11-2004 23:44:08
 Re: Rotobaler twine in reply to Jeff Oliver, 10-11-2004 21:01:54
On my NI round baler I use 16000 foot twine. I'm not sure if it is the same size ball as binder twine, but it might be. Some people refer to twine as 7000 lb, 9000lb- green or other color. Green twine is not stronger than any other- it is dyed green. 7000 refers to the feet per ball, 9000 is the same, so a 9000 ball is thinner twine, with more feet per ball, hence the ball is the same size, but the twine has a lower tensile strength, and breaks easier. Back in the 50s, Dad used binder twine in the AC baler, same as what was used in corn and grain binders in previous decades, but I don't know what is available now. I would just measure the available balls to see if they fit in the twine box of the AC.
