Hi; Congrats on your "new RC", what' it's ser # ? The RC is set up same as WC so look for a WC to see how it is done. The amp meter box lives under the bracket that holds the gas tank up and is also the mounting for the two front lights. The box mounts to the unerside of the bracket near the back. you should find bolt holes. The ampmeter box also holds the light switch. The choke rod goes back all the way from the carb to the front edge of the differential. There is a a foot rest that bolts to the front of the differential just to the right of the clutch. The foot rest has a slot at its lower left corner where the rod goes through. If you want to make your own choke rod you will be hard put to come up with the correct combination of bends without one to copy. The starter rod goes from the starter switch to the rear end as well. There should be a hole in a bracket bolted to the top left of the metal foot rest. The back end of the starter rod goes through the hole in the bracket, the front end of the starter rod goes through a lever that is hinged to the starter switch. The lever on the starter switch is about 2 inches long and pushes on the button on the starter switch when the starter rod moves. The starter rod also has a pig tail loop the back end so you can use your foot to operate it. Again if you want to make one, you really need an originl to copy. Have fun with the cute little tractor. D.D.Post
