WC engine modifications
Farmall Daddy
10-10-2004 17:51:42
I have a military WC that has the 4 1/8 piston oversize kit, by a 4 inch stroke. My question is, is it possible to put a D-17, or WD-45 head on the WC block? Is it possible to run a WD-45 crank, and still be able to run the WC head? Thanks for any input guys/gals!
wdTom
10-11-2004 18:42:33
 Re: WC engine modifications in reply to Farmall Daddy, 10-10-2004 17:51:42
You can run a 45 crank. I think a 45 head will work but you will need longer studs as later heads were "tall". You will need 45 pistons to run a 45 crank, they have the pin hole higher to allow for the longer stroke and they will have the "power crater" which is good for more power. The heads are all flat on the bottom, the combustion chamber is in the cylinder/piston, that is the piston doesn't come all the way to the top of the cylinder.
mf440
10-18-2004 09:03:08
 Re: WC engine modifications in reply to wdTom, 10-11-2004 18:42:33
you can still run the WC pistons it will raise your compression. With the WC pistons you may need to run 110 octain fuel to make it run decent.
