D17 Hydraulic Pressure
DennisMN
10-10-2004 17:38:28
Does anyone know the hydraulic working pressure on a D17 Series I ? The tractor has a Allis loader that seems weak. I put a gauge on the system and the pressure goes up to 2000 psi then drops immediately to 1500 psi. There are no external leaks in the system. Thanx in advance for the help.
Lil-Farmer
10-10-2004 17:42:55
 Re: D17 Hydraulic Pressure in reply to DennisMN, 10-10-2004 17:38:28
If I remember correcly, it should be somewhere between 3750 and 4000 psi. Your pump is unloading way too soon and probably could stand a good rebuild.
DennisMN
10-11-2004 05:18:21
 Re: D17 Hydraulic Pressure in reply to Lil-Farmer, 10-10-2004 17:42:55
Forgot to mention that it chatters when operating. I guess I'll look at a pump rebuild. Thank you.
