WC problems
shaun
10-10-2004 15:27:02
hey everyone, i have an allis chalmers wc tractor that my dad and i are restoring.we took the oil pan off because we werent getting oil pressure.it turned out the oil pump was good but the rod that is attached to the oil pump gear is striped. the gear on the rod is striped. how much would it cost to replace that and how hard is it? thanks for reading! email is [email protected]
shaun
10-11-2004 08:12:05
 Re: WC problems in reply to shaun, 10-10-2004 15:27:02
i really dont know how to do all this stuff. is it still possible to do it without removing the engine?i dont even have an engine stand.is the shaft tide into the timeing gears also? i hope this works out on my tractor. i have never done this before and dont know what mess im getting into. thanks for your advice post a followup if you can
gene
10-11-2004 09:13:43
 Re: WC problems in reply to shaun, 10-11-2004 08:12:05
Removing the cam shaft is possible without removing the entire engine. The cam shaft is meshed with the timing gears on the front of the block.
Suggestion. Before you start. Take some classes, if offered, from the local high school in mechanics. In central Missouri the trade school classes are offered off the high school campus - during the school day. If you get into one of these classes, you have a great shop project. Check with your career/guidence counselor. Future Farmers of America (FFA) also the 4H organization may offer instruction.
Last comment. This project is going to take some time and money. I have been working on one 36 WC for three years - and I'm a fairly good mechanic - used to teach auto mechanics - retired shop teacher. Some people have taken as long as 7 years to restore a tractor.
gene
10-10-2004 17:09:45
Just purchase a rebuilt oil pump. Several advertisers on this site should jump in and proved contact information.
The oil pump drives off of the cam shaft. Check the cam shaft oil pump drive gear for damage.
shaun
10-10-2004 18:09:34
 Re: WC problems in reply to gene, 10-10-2004 17:09:45
thanks for the followup. my pump is fine put the gear on the camshaft is tore up and wont drive the oil pump. how hard will it be to put a new camshaft in? thanks
gene
10-10-2004 21:04:49
 Re: WC problems in reply to shaun, 10-10-2004 18:09:34
Well, this depends upon your mechanical ability and equipment on hand. This is going to be a major under taking. You should be able to replace the cam without removing the engine from the tractor. I would pull the engine and put it on an engine stand. This will make disassembling part of the engine much easier.
Ok here goes. You need to remove everything in front of the engine block - the hood, radiator, loosen the hand crank starter bracket, the fan belt pulley from the crank shaft, the water pump, the front cover. Rotate the engine until the timing marks on the camshaft and crankshaft line up. Remove the two bolts holding the camshaft bracket to the block. If the engine is still in the tractor, now for the tricky part you. You need to hold up the tappets while you slide the cam shaft out. This is much easier on an engine stand - you simply turn the engine upside down and the tappets fall down - away from the cam.
I would also replace the cam bearings with the cam. You might want to consider doing an engine overhaul.
Gene
