wd clutch stuck
Richard Baugher
10-07-2004 09:53:26
My brother just got a wd with foot clutch stuck . What is some ways to unstick. Hand clutch works fine.
punchie
10-07-2004 14:32:10
 Re: wd clutch stuck in reply to Richard Baugher, 10-07-2004 09:53:26
HI Richard
First check the forks that thouch the throw -out bearing. They should not be in contact withthe bearing unless you are using the clutch. I set my around 1/8 " . They should have only a small wear mark not wore allot.
I would say if that does not do it. Using hand clutch and make the tractor jerk hard, almost jumping the front tires see if that does it.
