WD vs WD45 engines ... some questions?
New Here
10-07-2004 08:08:57
Friend of mine just bought what he thinks is a WD45 (decals say that) but somebody told him the WD45's all had some sort of "power crater" engine where the engine block on the right (push rod) side was cast with the block (as opposed to having a steel removeable side block plate). His has the removeable plate. He's a bit confused. And were there any other differences (if that engine thing is one difference) between the WD's and the WD45's?
Scott-IA
10-08-2004 08:38:23
 Re: WD vs WD45 engines ... some questions? in reply to New Here, 10-07-2004 08:08:57
Actually, the first year that they made the WD45, they used the wd block. Thus a few did have the plate on the side. The next year, they got rid of the plate.
it's possible that he has an early wd45, or a transplant engine.
JMS/MN
10-08-2004 21:39:55
 Re: WD vs WD45 engines ... some questions? in reply to Scott-IA, 10-08-2004 08:38:23
I do not agree. In 1953, AC made some WD tractors with the newer transmission and the curved shift lever. They still had the WD block with the plate on the right side. They were WD tractors. The WD45 came out with the Power Crater engine, no plate, and the new transmission with the angle cut gears and the curved shift lever, Traction Booster gauge, bigger standard tires, etc. They produced that same tractor until 1957.
Roy (MD)
10-08-2004 10:02:46
 Re: WD vs WD45 engines ... some questions? in reply to Jim Danforth, 10-07-2004 08:24:37
Dan,
Is that the only difference, internally, between the two engines? Just the crank?
Just wondering.
Roy
