2-Way hydraulic valve installation, WD
Garry Mumm
10-06-2004 06:15:37
I want to install a 2-Way hydraulic valve to operate the remote cylinder on a tiling machine. I am not a hydraulics guy so I need to know the specifics on waht type valve and the connections necessary to make the valve work with the WD pump. Thanks
David_T (MO)
10-06-2004 10:25:16
 Re: 2-Way hydraulic valve installation, WD in reply to Garry Mumm, 10-06-2004 06:15:37
Much has been said on this so a search should turn up a great many details on different ways to make this work.
The short version is... any modern valve should work. Set the pump and hand control to full output, run the hydraulic line to your new valve, run a return line back to the hydraulic reservoir (either through the fill cap or tee into the drain plug.
Got to watch your pressures though. Modern equipment are high volume/low pressure (2000 psi) systems. The old WDs are low volume/high pressure (3500 psi) systems. Modern cylinders run from WD style pumps will be slow and could blow if you over-pressure them. Best to consider a pressure relief valve set at 2000 psi somewhere in your new valve bank.
Hope that gets you started.
