Picture Request - C
Ryan-WI
10-04-2004 20:50:14
I purchased an allis C that the clutch spring had broke on. This is the spring that make sure that the pedal can not flip forward. Currently my clutch pedal can flip all the way back which then makes it difficult to press, especially in an emergency. Would someone be kind enough to post a pic of a close up view of the clutch pedal and linkages on a C?
tia
ryan
D Brown Utah
10-08-2004 01:15:34
 Re: Picture Request - C in reply to Ryan-WI, 10-04-2004 20:50:14
on my C there is a lug coming from the tourque tube to stop the clutch from going all the way foward. when i got mine the shaft that the clutch pedal pivot's on was so worn the pedal would miss the lug. I had to replace the shaft. this fixed mine.
Dick L
10-05-2004 06:11:06
You have more wrong than the spring. The threaded end in the throwout yoke ar stripped, broke off, or never properly assembled some time or other.
The spring on the C I use to pull is in the tool box in the truck. I bought it at one of the shows and never got around to put it on. That really does not cause a problem.
