Tractor pull Sunday
wdTom
10-04-2004 18:31:52
Well yesterday there was a truck show a few miles from home and they had a few of the antique tractor guys come and put on a pull. I loaded the AC B on the trailer and put it behind my WD and off to the pull. I haven't really used the WD much as I have only recently got it going. Still haven't got the hood and radiator sheetmetal on, but is looking orange and seems to be runnin strong. The B did really well pulling as the tires are loaded. WD ran well but is too light in back. It was very informal, just pull when you want and then they add a block, was a long chain so no wheelies and wheelie bars not needed. Had a good time and you should have heard the WD going wide open with the trailer and B behind when we got to the two short but steep hills out on the road!!
wdTom
10-06-2004 17:39:37
 Re: Tractor pull Sunday in reply to redcub, 10-05-2004 18:03:29
They are the standard size for a WD, don't remember the size off hand. There is no weight on it. I know how to make it pull, just put weight on it Until it weighs and balances as needed. Wasn't a serious competition, for me or the others, just a fun pull and a chance to get out with the tractor. It still needs a lot of work before it is finished, but is running and useable now. The hood and cowling are rough and need a lot of work. Probably get reproductions, Need to go through the hydraulic cylinders, and maybe the pump. Got to take apart the drawbar and spring loaded drawbar bracket under the tractor and clean, rebuild and paint. The front steering pedestal needs to be taken apart and put toghther- repair as found necessary. As I said I still have a lot to do, maybe this winter will see it mostly done.
