wd45 manifold gaskets
Pete Churilla
09-29-2004 03:47:56
Can someone please describe how the gaskets and the metal rings are assembled.Did not take this one apart and the I.T. shop manual is no help.
Thanks Pete
BushogPapa
09-29-2004 18:37:54
 Re: wd45 manifold gaskets in reply to Pete Churilla, 09-29-2004 03:47:56
Rub High-Temp Gasket maker into the asbestose gaskets, and they will stick to the manifond and the metal rings will stick to them..makes them last longer, and is a heck of a lot easier to install...!!
Aaron SEIA
09-29-2004 06:49:05
Put the metal ring against the head, lip out. The fiber gasket goes between the ring and the manifold. Bit of a trick keeping them from falling out while you move the manifold, but it's not too bad.
Aaron SEIA
