WD Transmission
Steve C
09-28-2004 16:08:09
After removing the bearing retainer for the pinion shaft, I found the left bottom bolt hole was cracked on both sides of the hole up to the snap ring. Is this time for a different housing?
Brad Sw Ia.
09-30-2004 07:34:04
 Re: WD Transmission in reply to Steve C, 09-28-2004 16:08:09
Steve, apparently someone, in the past, let the rearend get low on oil. The bearings on the pinion shaft get hot when run dry, then they expand and break the main case. There are two bearings back to back, you might check those, may need replaced. Those also, (if the main case is not broken) are pressed into rear end housing, pretty snug. If the case is broken, they should come out fairly easy, but could be stuck on pinion shaft. All depends what you plan on doing with your WD, if you change the main case or not. If you're going to use it quite a bit, I'd change it. Must remember, tractor serial number is located on the main case, also. Thanks Brad Sw Ia.
