HOW TO CLEAN GLEANER SHEET METAL
TIM5
09-27-2004 07:15:06
I bought an L2 gleaner and the galvanized sheet metal is weatherd and is rust stained in some areas is there a way to make the sheet metal look better
ANGLE IRON
09-28-2004 14:12:52
 Re: HOW TO CLEAN GLEANER SHEET METAL in reply to TIM5, 09-27-2004 07:15:06
Don't use the acid it will break the the coating down and cause more problems than it solves. The spray galv works pretty well to protect but will look like gray primer. Not even a close match to the original look. Just my thoughts.
acorange
09-28-2004 09:57:26
Just do the same thing that you are supposed to
do with galvanized roofing. Wipe it down with
automatic trans. fluid. It will both clean and
protect it. my 2 cents...
TexasAllis
09-28-2004 05:17:04
I have used CLR in a pump up sprayer to remove rust stains on siding. Might work on the galvanized sheet metal.
jerryh
09-27-2004 07:23:08
I remember my dad useing muratic acid and reduceing it with water then spraying it on waiting then hoseing it off. Hope this helps.
mojo
09-28-2004 04:54:40
 Re: HOW TO CLEAN GLEANER SHEET METAL in reply to jerryh, 09-27-2004 07:23:08
I see they now sell cold galganizing paint, never have used it but it's would a shot in this case. Wondering how it'd work on rims.
old don
09-28-2004 18:08:48
 Re: HOW TO CLEAN GLEANER SHEET METAL in reply to mojo, 09-28-2004 04:54:40
Well, there have been lots of suggestions over the years on what to use and one was naval jelly buuutt!!!Whatever you use I would suggest trying an area where it is not openly visible to see how it turns out. I personaly suggest using Mother's rubbing compound with a mouse sander and if it works coat it with wax to preserve the shine. I've seen Mothers do wonders on old harleys and it makes a nice winter project but in your case maybe winter, spring and summer. That L is a big sucker.Question, is that a black or orange engine L2? 145 or 158hp? good luck nice machine.
tim5
09-29-2004 05:07:44
 Re: HOW TO CLEAN GLEANER SHEET METAL in reply to old don, 09-28-2004 18:08:48
it is the orange 158 horse engine
old don
09-29-2004 18:34:12
 Re: HOW TO CLEAN GLEANER SHEET METAL in reply to tim5, 09-29-2004 05:07:44
Congrats, you have a 426ci vs 301ci, better known as the 670T engine same as the engine in the 7045 turbocharged non intercooled versus the 649I which is the same as the 7020. Both are very reliable, my guess is you either have a Rice/Soybean Special or L2KS or Corn PLus. Does it have Hydro traction or gear drive? The L2 is a nice machine.In 1984 I won an award for the best bin sample for popcorn beating out all the axial flows and whatever with an L3Corn Plus with an 8 row head. If you have any questions about that particular Gleaner let me know. Good Luck
tim5
09-30-2004 05:26:19
 Re: HOW TO CLEAN GLEANER SHEET METAL in reply to old don, 09-29-2004 18:34:12
it does have the hydro, and thanks
