D17 series 4
Bruce
06-02-1999 07:34:33
How do you determine the engine model and displacement on this tractor. I need to rering it with new head and exuast gaskets.Are there jober listings for it? From Edmonton Alberta Canada
Brian
06-13-1999 20:24:43
 Re: D17 series 4 in reply to Bruce, 06-02-1999 07:34:33
Try the store at the front of this site. They have some good prices on engine kits. If it were mine, I'd open it up and see whats needed. I thought I could do just a rering and bearing on a CA of mine, it didn't sound bad but when I got it apart, I was suprised at how worn it was and it still ran good. If you have a gas burner its a 226 cid 4 cyl. If diesel, 262 cid 6 cyl.
Len
06-03-1999 22:00:55
I think all D17 have either a 226 4 cylinder gas or a 262 6 cylinder diesel. But if it has previously been overhauled with aftermarket pistons and sleeves, you may have trouble finding rings. If it's gas, is bore still stock 4"?
Elmer
06-03-1999 15:38:10
Sealed Power had all the peices i needed to do a D17 deisel. Check your local Uap/Napa dealer.
john
06-03-1999 06:39:00
Go to your local AGCO dealer. You can find the closest dealer on the AGCO web site if you don't know where there is one.
