Duel tires on a G??
Seabee (Ga)
09-26-2004 18:56:39
I want to install duel rear tires on a G. Can I use the same lug bolts and just bolt both wheels together or is some type spacer needed? Not a work tractor, just a fun one..
acd17toy
09-26-2004 20:40:36
 Re: Duel tires on a G?? in reply to Seabee (Ga), 09-26-2004 18:56:39
i have duals for my G. i use a spacer band and just bolt the dual to the center disk in the other set of bolt holes.
Texas Denny
09-26-2004 20:17:44
Based on my memory when I restored mine, I concluded that new long lug bolts might be needed but that you could double them up easily. The way the wheel is made, you would be able to adjust how far apart they duals are.
