e combine engine in wd 45
zach
09-26-2004 17:37:11
Im in need of a engine for my wd 45 and i have heard that a engine from a gleaner model e will work. I know were i can get a good one cheap. Is this a direct swap and does everything bolt up like the clutch and so fourth? Thanks for any info.
slowsmoke
10-01-2004 04:38:40
 Re: e combine engine in wd 45 in reply to zach, 09-26-2004 17:37:11
motor bolts right in. I put an E/3 in a WC. used WC flywheel/clutch. WC water pump(holes need drilled out for larger bolts) Used front cover off WD45, for govenor (two holes need drilled for larger bolts.) used front pulley from WC.
Good luck, Don
zach
09-29-2004 08:10:45
Is there any body that has done the swap themselves that know for sure?
bryan g in mo
09-28-2004 18:48:49
I'm fixin to do the same thing, I've been told that you use the tractor flywheel, use the front pulley ffrom the tractor but it has to be bored out to fit the crank on the new engine, and either make a adaptor plate for the water pump or a real thick gasket, the water pump for the gleaner has three mounting bolts, the tractor has only two. Hope this helps, don't know if it is all right, hope so it will make my swap much easier.
old don
09-28-2004 18:22:49
zach, just so you know Leroi made the engine for AC (the air compressor people) if you can find an old Leroi compressor and know what you're looking for that would work too but as the other gentleman said you will probably have to change some things. A lot of people thing that AC made their own engine but guess what? That is why the WD and 45 had such a snappy govenor. Good Luck.
DanD.
09-28-2004 18:47:08
 Re: e combine engine in wd 45 in reply to old don, 09-28-2004 18:22:49
Both the WD45 and Gleaner E engines were made by Allis-Chalmers. THey were not made by any other company.
old don
09-29-2004 18:38:14
 Re: e combine engine in wd 45 in reply to DanD., 09-28-2004 18:47:08
Where was the AC tractor engine plant located in this era?
zach
09-27-2004 11:12:32
Any body know?
JMS/MN
09-27-2004 11:56:30
 Re: e combine engine in wd 45 in reply to zach, 09-27-2004 11:12:32
Yes- it does work. There are some differences. I think the combine engine has a fuel pump, which you don't need on the tractor. I think you remove the pump and make a cover for the hole in the engine casting. Imagine you'll need to remove the pulley and use the tractor pulley- don't know about the E, but many Gleaners run a two sheave pulley to run the fan and hudraulic pump. Might also need to use the original tractor governor as well. Bottom line is- the block is basically the same and will bolt into the tractor. Minor external differences. You're lucky to still find an E engine to put in there. Most are already snapped up.
zach
09-27-2004 17:28:30
 Re: e combine engine in wd 45 in reply to JMS/MN, 09-27-2004 11:56:30
Thanks thats good to know i will proably take it out this weekend now that i know for sure.
