WD 45 manifold
Greg In Iowa
09-26-2004 08:33:03
I have been looking at some pictures of new manifolds for my 45 and it appears that some are different. Who has the best and where should I get it? It turns out I need a new one... Mine has the 2 outer ports eaten up by heat/cancer.
Thanks,
Greg
Greg In Iowa
09-28-2004 19:03:51
 Re: WD 45 manifold in reply to Greg In Iowa, 09-26-2004 08:33:03
Thanks guys.... I could surface this one, but it is pretty thin on those two outer ports. I just want it to be good and be able to use the A-C muffler... I don't want to have to use some off-breed thing.
Greg
Texas Denny
09-26-2004 20:19:59
If you have access to a milling machine, I saved two of these by milling the surface of all the ports down until I had good metal every where.
Bushogpapa
09-26-2004 19:04:32
I have a good one...where are you located..??? It is off a Gas WD-45..
I an in Central Ohio.. Ron..
