Wiring AC-B that has magneto and alternator.
Daniel W. Fry
09-24-2004 13:37:40
I purchased a napa universal KSI-32 switch as recommended for use with the magneto. Switch has 4 terminals and a ground terminal. The switch is keyed. positions are off, then another position, then another position, then a position that returns after you release the key. Apparently use for starting. I need to know where to attach wires correctly on the switch.
Duey (IA)
09-25-2004 19:32:44
 Re: Wiring AC-B that has magneto and alternator. in reply to Daniel W. Fry Sr, 09-24-2004 13:37:40
Daniel,
Check out the wire diagrams and info on my website. I have the NAPA # for use with the mag.
Rod (NH)
09-24-2004 16:24:37
Hi Daniel,
I assume you are talking about a three wire, internally regulated alternator like the Delco 10SI. I don't know about that particular NAPA switch because I used a DPDT two position toggle switch instead. In the "off" position the magneto stud needs to be connected to ground through the switch while at the same time the #1 control terminal on the alternator needs to be disconnected from battery + voltage. In the "on" position the magneto stud needs to be opened to ground through the switch while at the same time the #1 control terminal on the alternator needs to be connected to battery + voltage (through a low amperage fuse). If you want to use your key switch to also energize the starter you will need to add a 12v starter solenoid that gets energized when the switch is in the momentary "start" position. I use a separate two position, normally open push button switch for starting.
You will need to use a continuity tester to see exactly which terminals on your particular switch make and break contact in the different switch positions.
third party image Rod
Daniel W. Fry Sr
09-24-2004 18:18:05
 Re: Wiring AC-B that has magneto and alternator. in reply to Rod (NH), 09-24-2004 16:24:37
Thanks for the quick response. I should probably return the NAPA switch and find a DPDT two position switch instead.
