Henderson Loader Hyd. pump
B. Junkins
09-24-2004 05:17:12
I have a question regarding the hydraulic pump used on the Henderson Manure loaders. I have one mounted on my 38' "B", and have a feeling that it is a 2-way pump, but I'm not sure. The pump mounts on the rear, directly to the PTO shaft. It looks like a small barrel. When I lower the bucket to the ground, it seems to apply pressure in the "down" position, even after it rests on the ground. The cylinders/rams are about 36"long or so, and they are only one-way, however, the pump seems to apply pressure in the down motion. Could this pump actually be working the down motion by vacuume?
I'm amazed at the lifting power of this rare loader. The only down-fall is that the pump isn't "live", and takes some getting used to.
Any info/input about this loader is greatly appreciated
