WD TRANSMISSION CAPACITY
NEWTO ALLIS
09-22-2004 10:31:12
I need to fill the transmission with gear lube and was wondering if someone could tell me how much it takes and what weight of gear lube. Thanks
wdTom
09-22-2004 17:23:22
 Re: WD TRANSMISSION CAPACITY in reply to NEWTO ALLIS, 09-22-2004 10:31:12
Remember that there are two fill plugs. Both on the left side of the transmission, to the rear of the hydraulic fill/dipstick. As for the final drives, good to do, many don't get done very often, you have to take the pans off the bottom, clean them, reinstall them, then fill to the bottom of the fill plug on the side of the pan. Is easier with the wheel out wide or off the tractor.
Sid
09-22-2004 13:43:50
From the owners manual TRANSMISSION,DIFFERENTIAL&CLUTCH. . . 17 Quarts (18quarts with P.T.O. installed) Use *SAE 80ep all year.
Dave Grubb
09-22-2004 11:12:19
I don't have my owners manual handy but the transmission is filled to overflow. The rear end and final drives are also filled to overflow. 80W90 or 80W190 is a good choice for gear lube in all three.
