I need some wiring help
Scott-IA
09-21-2004 15:21:57
I'm rewiring my wd45, and converting back to original 6v, but I've got some wiring questions. I hope you guys can tell me if I'm right here.
Wire from starter as power to - side of ammeter. + side of ammeter to ignition switch, head light switch, and 'bat' terminal on the regulator (converting to regulator also). F on regulator to F on genny. G on reg to A on genny.
Is that correct? Also, what guage would you use on all of this? I was told 12ga would be good, but I was thinking 10ga on genny and regulator wires.
So, am I missing anything? Will 12ga work just as good?
Thanks for the help guys!
steve(ill)
09-21-2004 15:36:44
 Re: I need some wiring help in reply to Scott-IA, 09-21-2004 15:21:57
so far so good. i commented onALLIS forum also. appears you are positive ground, and back to original. if you go with a voltage regulator make sure it is acceptabe to positive ground, and is rated at 6 volts. 12 gauge wire is acceptable for 20 amps, the generator does not put out that much.
Scott-IA
09-21-2004 16:07:32
 Re: I need some wiring help in reply to steve(ill), 09-21-2004 15:36:44
Steve, Thanks for the reply. Looks like I'm wiring with 12.
