WD-45 Gas Cap
Phill Snartland
09-20-2004 08:58:45
I just found an original gas tank cap for the WD-45 I'm restoring. One question I have is that it doesn't seem to be vented. Aren't most gas caps vented and will I have problems with running if I use this non-vented cap? I'd hate to draw a vacuum and dent the tank I just spent so much time getting the dents out of.
Can I just drill a small hole to let the air move in and out?
Thanks for your ideas.
Texas Denny
09-21-2004 19:25:23
 Re: WD-45 Gas Cap in reply to Phill Snartland, 09-20-2004 08:58:45
My original WD-45 cap is vented.
Phill Snartland
09-22-2004 05:18:16
 Re: WD-45 Gas Cap in reply to Texas Denny, 09-21-2004 19:25:23
I wonder if what I found is a radiator cap. Denny, how does the venting on your cap work? is there a hole for air movement? Some other way for air to move in and out of the tank? Any help would be appreciated!
Phill
Texas Denny
09-26-2004 20:54:26
 Re: WD-45 Gas Cap in reply to Phill Snartland, 09-22-2004 05:18:16
yes there is a very small hole. The radiator cap doesn't have a hole. Otherwise they look the same.
