Model B questions
Steve Jelf
09-19-2004 20:16:36
I don�t have much experience with tractors of any kind, so I hope some of you Model B & C experts can help with the following: My 1945 Model B will not shut off with the ground switch, or even with a screwdriver across the post on the magneto to the magneto body. I have to kill the tractor with the choke. I took the ammeter off the B and tested it and it�s OK, but on the tractor it shows no charge or discharge, either starting or running. This tractor has a voltage regulator (not just a cutout) on the generator, and no lights. The Zenith carburetor on this B has a needle valve for the main jet where the service and operating manuals show a plug. Is this right? Unfortunately this carburetor has been soaked in carburetor cleaner and the numbers are gone from the aluminum disk, so I don�t know exactly which carburetor it is.
CH
09-20-2004 16:26:00
 Re: Model B questions in reply to Steve Jelf, 09-19-2004 20:16:36
As far as your carb goes, I have one with the adjustable jet and one with the fixed jet. If you need the numbers off the disk, I'll take a look. I just rebuilt both. You can get the kits at NAPA.
Steve Jelf
09-20-2004 17:12:13
 Re: Model B questions in reply to CH, 09-20-2004 16:26:00
You bet, I'd like to get the numbers from the adjustable jet Zenith. It might be instructive also to see if the two tractors are contemporary. Mine is serial #71019. Is yours close to that?
CH
09-20-2004 17:44:47
 Re: Model B questions in reply to Steve Jelf, 09-20-2004 17:12:13
Model 8561, type 206989. This was off my '38 B. It's made for a 116 ci engine. It might not be the original. My '39 has the fixed jet. The NAPA Echlin part # is 2-1565 for the rebuild kit. It's the same kit for both carbs.
Hope this helps.
Charlie
Ted Seifert
09-20-2004 10:24:43
The internal wire of the magneto that goes to the screw where you are trying to shut it off may be broken off. The other problems are not related.
JMS/MN
09-19-2004 21:58:55
If it is a magneto ignition, check for paint or rust on both sides of the ground switch. It should shut off with good connections.
steve(ill)
09-20-2004 20:30:14
 Re: Model B questions in reply to JMS/MN, 09-19-2004 21:58:55
the terminal on the mag is grounded inside. if the wire is broke you can not "kill". what you are doing is grounding the mag with that terminal.
---normal 6 volt is a cutout. you could have a 6 volt regulator if it was converted. the regulator takes the place of the cutout and the light switch resistor (both). if you have a 12 volt battery, it need a regulator not a coutout.
