allis chalmers serial numbers
scott smith
09-19-2004 09:17:18
I have a WD the only numbers that I found were on the back of the engine on the left hand side WD334696PA. Is this the engine serial number? Can some one tell me what size engine is this so Ican order parts.
Aaron SEIA
09-19-2004 09:48:06
 Re: allis chalmers serial numbers in reply to scott smith, 09-19-2004 09:17:18
It's either a 201 or a 226, depending on which crankshaft it has in it. Makes no difference on most parts other than pistons and you'd have to drop the oil pan or pull the head to tell for sure what you've got. Tractor serial number is stamped on the left rear brake housing, just above the brake spring hole.
Aaron SEIA
