Allis Chalmers 1 Bottom Pull Behind
Tom H
09-17-2004 19:25:47
I just picked up a 1 bottom plow made by Allis Chalmers. It is a pull type. I need to get a new plow share. Does anyone know where I can find a share. The plow was designed for a model B and has the number 309212 stamped on the back of the moldboard. Is this the model of the plow? Thanks for your help in advance.
Tom
Tom H
09-19-2004 15:09:57
 Re: Allis Chalmers 1 Bottom Pull Behind in reply to Tom H, 09-17-2004 19:25:47
Rod,
Thanks for your help. How difficult is it to find a 16" #325 bottom? I noticed that they still make some shares for Allis Chalmers in the Valu Bilt Tractor Parts catalog, but none of this type.
Thanks again,
Tom
Rod (NH)
09-19-2004 19:59:17
 Re: Allis Chalmers 1 Bottom Pull Behind in reply to Tom H, 09-19-2004 15:09:57
Tom,
I have no idea where you might find a share for your plow. For your info, Here's a pdf file showing the parts for the #325 bottom used with B/C pickup plows. Please let me know when you have downloaded it so I can delete it from my site to save space. If I don't hear, I'll just delete it after a couple of days.
Good luck in finding something that might work, even if it is not the exact replacement part number.
Tom H
09-19-2004 20:22:25
 Re: Allis Chalmers 1 Bottom Pull Behind in reply to Rod (NH), 09-19-2004 19:59:17
Rod,
I got the information...thanks again for all of your help.
Tom
Rod (NH)
09-18-2004 09:30:15
Hi Tom,
The parts book for the AC-B/C two way pickup plows (mounted, not pull behind) indicates that part number 309212 is for a moldboard only. It is one of the several different moldboards supplied with different plow bottoms used on the B/C pickup plows. The 309212 moldboard was used on a right hand, 16", "#325" bottom. That same moldboard/bottom might also be used with other, different plow assemblies.
third party image Rod
