HD3 loader with henry backhoe
nick
05-30-1999 20:43:07
I am having problems with the hoe. the extend arm does not work in either direction in or out.
I put new packing in the cylinder, It did not change a thing.
I removed the spool from the directional valve, spring looks alright. where does the o-ring go?
when I poped out the spool,found a o-ring floating on the shaft. The hoe is a henry manufactured for allia-chalmers, model MARK V
serial no 4b1151AO. need help
