WD hydraulics
Brio Bean
09-17-2004 10:18:46
I have a 3 pt hitch for my WD. I can"t keep an implement at a constant level. The hitch goes up and down but will not stay put. I believe the pump has been set to the lift hold position. Does anyone have any ideas on how to correct this. Thanks, Carl
Tom Yaz
09-17-2004 10:37:14
 Re: WD hydraulics in reply to Brio Bean, 09-17-2004 10:18:46
Assuming you have the settings correct and the linkage adjusted accordingly, Your check ball may be bad. It is found in the bottle like device on top of the pump. Need to get a new one from AGCO, supposed to whack it out with a hammer, but I never did it myself. I had the dealer fix it.
brio bean
09-21-2004 07:58:57
 Re: WD hydraulics in reply to Tom Yaz, 09-17-2004 10:37:14
Thanks Tom, I'm wondering if the linkage is adjusted right. The manuals I have are very confusing. The traction booster should be locked out, correct? The manual refers to a "detent" but what exactly is that?
