WD45 Clutch 9-spring pressure plate info needed
Rodd
09-16-2004 04:06:24
Hello all,
I've read the various recommendations of replacing a (bad) clutch w/6-spring pressure plate, with the heavier duty 9-spring plate version. Could anyone steer me toward where the 9-spring version can be found, or (hopefully) it's part number? Thanks in advance!!
Phill Snartland
09-21-2004 14:35:11
 Re: WD45 Clutch 9-spring pressure plate info neede in reply to Rodd, 09-16-2004 04:06:24
I got the parts to convert my 6-spring pressure plate to a 9-spring unit from Sandy Lake Implement, Sandy Lake, PA. (724) 376-2489. Ask for Brenda in Parts. Great to work with! Bolted right up, no problems. Pressure plate, clutch disk, throw-out bearing, and pilot bearing ran about $270. Depending on the age of your tractor, you'll have to have a sleeve machined for the pilot bearing, and you'll also have to machine or buy an alignment tool to put it all together.
Good Luck!
BushogPapa
09-17-2004 13:53:30
I think if your pressure plate is good, that you can add 3 more springs, or replace the 6 with 9 new ones... I wouldn't be too surprised if the Latest WD-45's, and early D-17's used the same 9 spring pressure plate.. Replace the seal just behind the clutch, before you put the clutch in..
Ron.
