53 wd 45
zach
09-14-2004 14:16:40
im looking at a 53 wd 45 wide front end. Has wrong fenders off a 180. Rest od metal good. good rear tires. motor unknow condition but not stuck and has been covered. Doesnt run. Has freeman trip loader. Guy wants 500$. What do you guys think? Should i buy it or not?
JMS/MN
09-15-2004 11:06:50
 Re: 53 wd 45 in reply to zach , 09-14-2004 14:16:40
I agree with Bob- it's a no brainer, if the wide front is an AC. They go for $400, and the rest is gravy. Good trtanny, tires, sheet metal, radiator, will more than pay the balance. Heck, a good shifter is 50!!!
BFreije
09-15-2004 10:32:11
I got two 1953 WD45's narrow fronts that run and can do a days work. If you want something ready to go that needs paint let me know. Bob
zach
09-15-2004 12:43:45
 Re: 53 wd 45 in reply to BFreije, 09-15-2004 10:32:11
How much you askin for them?
BFreije
09-16-2004 11:47:16
 Re: 53 wd 45 in reply to zach, 09-15-2004 12:43:45
I would take $1500 each, or If you want both I would take $2600 or $1300 each. Will put pix on Impliment Photos as Bob's WD45 There will be two pix.
wdTom
09-14-2004 17:20:50
If it is near me you don't want it. It must be junk for such a low price. If it is within a reasonable distance I will buy it and check it out and if it is anything you might want I will call you. Where is it?? Serious now. The wide front end and engine block are worth more than the price of the tractor. Everything else you get is gravy. Probably it can be made to run and be OK for a reasonable price unless something major is wrong, in which case you have the option of parting it out and making money.
zach
09-15-2004 07:55:23
 Re: 53 wd 45 in reply to wdTom, 09-14-2004 17:20:50
I did some more checking on it it has good anitfreeze in it so i dont think its been froze. The weired thing the guy says he put bearings and rings in it and grinded the valve. Theres no oil in the motor and it looks like the pans been of cause theres only 4 bolts holding it on. But its not stuck. I think im gonna but it this weekend
Bob D. (La)
09-14-2004 14:46:43
Down here I would have paid for it and had it home before I posted that question. HTH
