175 Hydraulic pump
Barry C
09-13-2004 20:38:07
I removed and dismantled my pump beacuse of a small noise. I replaced 2 of the brass wear plates where the gears ride. My problem is now it wont pump and doesn't seem to pick up fluid. This is the aluminum pump that fits on the side in place of the belt pulley. Is there a proper bleeding procedure? What if I take off the large rad type hose and pour fluid in the pump there?
Thanks in advance for any help.
Barry C
Kent of SW MO
09-14-2004 07:42:32
 Re: 175 Hydraulic pump in reply to Barry C, 09-13-2004 20:38:07
You may have put the pump back together wrong which can change it rotation. I did this on the hydraulic pump from a Gleaner C-II to use in another application.
Kent
