WD help needed
rwrage
09-13-2004 14:48:00
My WD runs on only 2 cylinders. The front two work great and will nearly kill the engine when the plug wire is pulled. Pulling the back two has very little effect on the engine. I have checked for compression and I have about 95 pounds per. I pulled the valve cover and all valves appear to function. This is a continuation of a post from awhile back. It uses a lot of gas and the engine oil becomes mixed with gas after some time. I have gone through the carburator and put new manifold gaskets on. Any Ideas?
Don McLaughlin
09-13-2004 21:48:46
 Re: WD help needed in reply to rwrage, 09-13-2004 14:48:00
I agree with Gene. Check that your plug wires did not get switched. I had a similar problem with no reaction when I pulled off the wires on #3 & #4. I checked the carb and other items before I thought of trying to switch the two wires. I never did find out who or when the wires got switched but that was the problem.
rwrage
09-29-2004 07:24:40
 Re: WD help needed in reply to Don McLaughlin, 09-13-2004 21:48:46
Don & Gene- You guys are great! Hit the nail on the head. A simple fix that had not occurred to me. I was positive that those wires had not been switched- but #3 and #4 were. Thanks!
Pat Cruise
09-13-2004 20:49:41
Sounds like you have a headgasket blown between cylinders.Had this happen on a Dodge 230 flathead in a M-37 weapons carrier once.still had compression on both cylinders because they were feeding each other.Replaced the headgasket and it ran great.Hope this helps!!!
Gene
09-13-2004 15:20:02
Sounds like an ignition issue. Did you see or hear a spark at the #3 & 4 cylinders when you pulled the plug wires? Doesn't sound like they are firing.
Check to see if the # 3 & 4 plug wires are in the correct distributor tower. Swap the # 3 & 4 wires at the plugs - see what happens.
No change. Replace the plug wires with copper core wires, check the back two plugs, check the rotor and distributor cap.
You have fuel and the ignition timing is correct or the tractor wouldn't run. Compression is good to great. Not much left to go wrong - plugs, wires, distributor cap - cracked.
Okie
09-13-2004 15:38:21
 Re: WD help needed in reply to Gene, 09-13-2004 15:20:02
Sounds like an intake leak to me, take some Wd-40 or something like it and spray where the intake bolts against the head. If it changes the way it runs you have a bad intake gasket. Okie
rwrage
09-15-2004 17:45:45
 Re: WD help needed in reply to Okie, 09-13-2004 15:38:21
Thanks for the suggestions, I will try the wires first. Hope that works! I have tried the WD40 on the intake valves and replaced those as well as the exhaust. I am working my way towards the head gasket, but I am finding some stubborn head bolts. Thanks to all, will post results.
