WTD: Allis HD6 Dozer dry clutch pressure plate ase
David Anderson
09-13-2004 11:29:29
Subject: WTD: Fiat Allis HD6 D clutch pressure plate asembly "Auburn"
Wanted: used clutch pressure plate assembly for a Fiat Allis HD6 Dozer Serial # 1442. My metallic clutch plate is OK and the mating cast pressure plate is OK. but missing 3 retractor, studs (broken), springs and locators.
The throwout bearing's internal bushing is worn-out and the throwout yoke pins and their bearings are worn right off.
Can send photos of damaged parts as well as .gif image of parts from service manual.
Alternate USA shipping address is "Ship Happens" 603 Cherry St., Sumas Wa. 98295.
I understand now that this is a common failure with the Auburn clutches when the machine is regularly left idling with the clutch disengaged.
David Anderson 7343 Catherwood St. Mission BC Ca. V2V4C5 Ph: 604 820-9716 Cell: 604-308-7461 (Aldergrove No.) Hamradio: VE7IFD, Mission Search & Rescue #31 Email: davidaanderson at telus.net ( change the "at" to "@")
Kent of SW MO
09-14-2004 07:35:33
 Re: WTD: Allis HD6 Dozer dry clutch pressure plate in reply to David Anderson, 09-13-2004 11:29:29
There is a clutch and driveline shop 20 miles south of me that can fix any clutch problem you have. Is there nit one in you area?
Kent
David Anderson
09-14-2004 09:22:55
 Re: WTD: Allis HD6 Dozer dry clutch pressure plate in reply to Kent of SW MO, 09-14-2004 07:35:33
Normally I would say "yes" but this darned pressure plate is a different animal, it has the throwout bearing inside a large casting with over centering knuckle fingers attaching it to the plate which has a spiral ramp adjuster.
There is a disc brake pad on the backside of the throwout bearing that meets up with a disc on the output shaft which is double "U" jointed to the transmission input shaft. I was told that Auburn had made them for Allis Chalmers and it"s the only Allis I"ve ever seen with one. David
Kent of SW MO
09-15-2004 06:37:07
 Re: WTD: Allis HD6 Dozer dry clutch pressure plate in reply to David Anderson, 09-14-2004 09:22:55
Give these guys a call:
BEST-BILT PARTS CO. INC. 2527 East Kearney Street Springfield, Missouri PH: 1-417-869-0703 1-417-869-7601 1-800-552-0036
They fix the pressure plate on an old H-3 that a buddy of mine had. This was some years ago just after the Allis ind. dealer closed in this area. I told him if BEST-BULT could not help him he was in a world of hurt. They got him going.
Kent
