d-15 shutle clutch use
jospuleo
09-12-2004 17:52:09
My d-15 has a dying engine clutch. I need to use it for some hard work before I can fix it next summer. Is it OK to just keep it in 2nd and use the shuttle clutch. Thanks
joe
Sid
09-12-2004 22:08:46
 Re: d-15 shutle clutch use in reply to jospuleo, 09-12-2004 17:52:09
That will make it easier on clutch but it is still no guarentee that the engine clutch will not slip under load. It all depends on what is wrong with the engine clutch
BC NC
09-12-2004 21:16:55
Absolutely. The Shuttle Clutch has nothing to do with the engine clutch, and breaks the powertrain motion just the same. The only time you need the engine clutch is when you shift gear ranges at a stop. If you only need 2nd gear you're okay. Good luck!
kevin from ontario
09-12-2004 18:43:29
yes it would be ok
jospuleo
09-13-2004 07:28:35
 Re: d-15 shutle clutch use in reply to kevin from ontario, 09-12-2004 18:43:29
Thanks, I thought this might be abusing the shutle clutch. Glad to hear its ok.
