WC Allis Engine
Charles
09-11-2004 19:13:52
I have a WC S/N wc49614 with motor S/N w80753k I'm trying to find out if this is the engine that came with the tractor and will it fit a wd45?
Thanks
Charles
Charles
09-15-2004 08:47:40
 Re: WC Allis Engine in reply to Charles, 09-11-2004 19:13:52
Thanks for the information. I thank I will just part it out. with bad wheels it's too much trouble to repair.
Thanks again
Charles
kevin from ontario
09-12-2004 18:45:50
yes the motor can be swaped just fine
Gene
09-11-2004 22:09:13
The engine serial number matches the WC tractor serial number. I don't know if that engine came with that tractor - probably did. "K" at the end of the motor serial number stands for standard compression (kerosene). A "G" would be the higher compression engine - gasoline only.
The WC has about 19 drawbar horsepower while the WD45 has 37 - 38 drawbar horsepower.
