A C model CA lift
pat
09-10-2004 15:30:43
I just purchased an A C model CA ser# indicates that it was made in 1951. I have a repair manual but it does not giv much info. it has a lot of oil leaking around the lift controll and PTO. I assume the lift and trans-axle have the same oil source. can someone tell me where to check the oil level and what kind.
steve(ill)
09-10-2004 18:40:47
 Re: A C model CA lift in reply to pat, 09-10-2004 15:30:43
the transmission, bevel gear and pto- hydraulics are all the same oil. there are 3 half inch pipe plugs under the tractor to drain the three compartments. the fill is by your left foot in the trans case. there is a dip stick ont he CA,not on the B or C. originally it had 20 wt oil in it. now the standard oil is universal hy-trans , you can get at Wal Mart or farm store. holds about 8-9 quarts. this is a 20 wt hydraulic oil, will say spec AGCO 821 on the back.
PAT
09-10-2004 19:32:08
 Re: A C model CA lift in reply to steve(ill), 09-10-2004 18:40:47
Thanks steve
