Nebraska test rated D-14 gas tractor at 31 hp at the draw bar. First thing you need to look out for is what you are going to do with your extra money when you sell that yuppie Ford and buy a real tractor. Seriously, the D-14 is a great tractor. Easy to convert back and forth to 3 point if you want to go that way, but the snap coupler equipment works great for ground tillage and is usually pretty inexpensive. The major trouble spot with the D-14, or any D or W series tractor, is the transmission. Years of gear grinding abuse can cause the tractors to want to jump out of gear. Third gear is usually the worst if the problem exists. Drive the tractor down hill in third gear at a high throttle setting and then suddenly close the throttle. The sudden change to engine braking will cause the tractor to jump out of gear if the transmission is worn too bad. OH!!! Be sure you check the brakes before you do this. If it's a steep hill, and it does jump out of gear, and you don't have good brakes... well it can be a wild ride. The transmission can be expensive to fix if that is necessary.
