help!
Rick Steele
09-09-2004 14:07:24
i went throught all the steps from inforamaton i got here and then started to adjust linkage. wheni got to the part where i was suppose to stand on lift and lower the lift control till the pump released, thats where it all stopped , nothing happened. the lift stayed up and wouldn't go down. so heres where i need help. Rick
Rick Steele
09-10-2004 17:25:18
 Re: help! in reply to Rick Steele, 09-09-2004 14:07:24
ok fellas , i took the pump off, and so far what i have found is that one of the rollers on one of the cam followers was all but gone. their are two others that have wore down probable a sixteenth to an eighth. one is perfect. so what i need to know know is with the rollers on the cam followers like they are , could that be my problem as to why the lift arms won't go down? i'm just guessing here. need a more experienced opinion.
steve(ill)
09-10-2004 18:55:22
 Re: help! in reply to Rick Steele, 09-10-2004 17:25:18
i dont know which model you are working on, but he B,C,CA rollers often show some wear. this effects the pump capacity, but should not effect the raise or lwer. the cam is actual the "pump". sounds like you have something stuck or broken in the "valve" which is the springs, spool and chekc ball area--- sorry.
Rick Steele
09-10-2004 19:06:49
 Re: help! in reply to steve(ill), 09-10-2004 18:55:22
steve i am working on a 1951 wd allis.
