AC 7020
Rev JJ
09-08-2004 19:13:36
Looking at one, 3500 hrs, has the T bar, ten speed shift.
Are 7020 pretty good machines? what should an old boy look out for?
old don
09-17-2004 18:52:46
 Re: AC 7020 in reply to Rev JJ, 09-08-2004 19:13:36
Nice tractor 301ci intercooled turbocharged diesel, always check the torque limiter put the tractor in high gear with engine at half throttle and hold the brakes if tractor pulls down and doesn't slip your good to go if it doesn't you're looking at a split job with a new torque limiter and rear engine seal also pull the side panels off the engine and check the condition of the foam seals around the radiator to keep foreign material from getting in the radiator from the sides and plugging up the radiator this has been a problem in the fall plowing with dry corn fodder. Good Luck
