Mod B govenor shaft removal
mikebramstedt
09-07-2004 09:15:51
Is there a trick to removing the govenor shaft on my Mod B? behind the Mag appears to be too small of an opening but behind the governor cover, the slanted teeth are in the way.
thanks,
mike
Dick L
09-07-2004 11:19:46
 Re: Mod B govenor shaft removal in reply to mikebramstedt, 09-07-2004 09:15:51
It comes out the front after the governer cover has been removed. You have to remove the magneto then remove a flat head retainer screw that is on an angle. It will push out the front without a great deal of pressure from your hand.
mikebramstedt
09-09-2004 06:36:26
 Re: Mod B govenor shaft removal in reply to Dick L, 09-07-2004 11:19:46
Thanks, Ok anyone have a shaft, gear and weight set for sale for an AC mod B with a magneto.
thanks
