WD 45 TIMING MARK INSPECTION HOLE
RAY LEAVER
09-06-2004 17:51:00
JUST BOUGHT A WD45 AND SET THE POINT GAP. I WANT TO TIME IT USING A TIMING LIGHT. WHERE IS THE TIMING MARK INSPECTION HOLE LOCATED?? IS IT ON THE PLUG SIDE OR FUEL BOWL SIDE??
Gene
09-06-2004 18:42:04
 Re: WD 45 TIMING MARK INSPECTION HOLE in reply to RAY LEAVER, 09-06-2004 17:51:00
The timing inspection hole is located under the bell housing. Timing marks are on the back side of the flywheel. Two marks "F" and "TDC", "F" mark should be centered in the inspection hole at fast idle.
RAYMOND LEAVER
09-11-2004 21:13:22
 Re: WD 45 TIMING MARK INSPECTION HOLE in reply to Gene, 09-06-2004 18:42:04
THANKS FOR THE INFO GENE---I TIMED MY WD45 AND SHE RUNS LIKE A TOP!!
