WD-45 manifold gaskets
wet in NY
09-06-2004 14:51:24
Trying to put on the manifold and am troubled. Do all 6 holes (intake and exhaust) use the same type of gaskets?
thanks!
BushogPapa
09-06-2004 17:50:04
 Re: WD-45 manifold gaskets in reply to wet in NY, 09-06-2004 14:51:24
It depends on which manifold you have..!! On the original manifold ( maybe all but the very latest), all gaskets and metal cups were round, and the same...on replacement manifolds, and maybe some of the later ones, the 2 end gaskets are rectangular.. I like to use High-temp Gasket-maker in the metal cups, and on the asbestos gaskets, to help seal them and also it helps assembly by holding all tha gaskets in place, while you slide the manifold back on... I think it makes the gaskets last a lot longer.. Ron.
